What it takes to install chrome handlebars on the RT
Not sure
Not sure on that, but if it's anything like the front it was just unplugged. He said removing the bolts and sliding it back off the frame would remove side bags and trunk at one time. I'm just guessing there could be a master plug or more that can be undone that allows it to do so. Next time I'm in there I going to pick his brain a little more. He just returned from BRP's tech school last week so he's bound to be much smarted now.
I went through the BRP advance Spyder tech school and that was not part of the class.
I know the back comes off like that and that's what BRP tells you to do when removing it but there's a lot more to the front than it. :dontknow:
not really.
You have to take off the normal plastic. Then remove front glove box and lay it to the side of bike. I know that being there is a cable attached to it. Look in near the speakers and you should see two bolts. One on each side. Remove those, then there are two up front under the headlight area. Unplug the harnesses by the oil fill. You then should be able to pull that unit forward off the frame. But then it leaves that whole handle bars unit exposed. Not sure about one thing, if you unplug these you may have to put it on the BUDS to clear codes? Man! now I wished I video tape it when he put it back together. But it's kinda one of those things where not sure he would have liked it.
