Hi Ben,
I met with my dealer yesterday about him putting a sway bar on my 2014 RT Limited. He tried to "sway" me away from it and to put Fox shocks on instead. He says his BRP rep also confirmed that the shocks would be better than the sway bar if I wanted flat turns.
While I'm very familiar with what a sway bar and what HD shocks do in a car, I don't want to feel all the jarring bumps and ruts on a bike with HD shocks. Since you have both the bar and the shocks, and while you have neutralized the body roll, would you do both again in the order you did, or would you take the dealer's approach and do just the Fox shocks? If you did the shocks first, would you still feel the need to put the sway bar on?
Jerry
Welcome to the forum, Jerry!
I think your dealer does not fully understand the benefits of upgrading to a beefier anti-sway bar on the Spyder. (Either that, or he just wants to sell you a set of shocks.
) Since you are familiar with the function of an anti-sway bar, you will understand that its function is very different from that of shocks, as Peter described a few messages above. If you are interested in flatening out your turns and in having to lean less to turns at higher speeds, then there is no question that you should try the BahaRon sway bar first. Yeah, I know, the bike already has an anti-sway bar on it, and I was also skeptical at first that just beefing it up a bit would make that much of improvement. But as I found out, as did hundreds more here on this forum,
it truly makes a BIG difference!
Like many have said here, I changed out my sway bar early - about a year after I bought the RT. And I received all the benefits from doing that that I described in
post #6 above (and in the link included it that post). But I came to realize that I still had a shock problem that had NOTHING to do with turning. I'm a big guy, and the front shocks on the bike were simply not doing the proper job for me - especially when I carried any weight in the frunk. The ride felt "spongy", I was porpoising when I braked or hit a bump, etc. I was about to upgrade to Elka shocks earlier this year when BahaRon came out with his shock adjusters for the 2013 and later RT's. I bought those instead and saved a bunch of money. They have a continuous adjustment, so I was able to try several degrees of tension with them to find that exact sweet spot between "too spongy" and "too harsh" a ride. (For me, it took exactly 4.5 turns.) Now I have a smooth comfortable ride with no porpoising, AND, because of the beefier sway bar, I also have much more stability in the turns, and I have to lean much less than I did before. (My dealer installed both of these mods for me, by the way.)
