What causes. Front left tire to wear on outside
Alabamajim
I. Have a 2010 RT and am getting excessive wear on the outside of right tisere. I have just over 13000 miles. Thanks for your help
tire ware
aliment is toeing out get it alined and check the ball joink mine was toeing in alinement was all i needed...........:D
OUTSIDE WEAR
You may be the first to report this type of wear......mostly it's inside edge = chamber issues usually.....being that it's only one tire and you have 13000 miles ...it's sounds like a mechanical problem other than normal alignment issues........Did the wear appear suddenly ??? or do you think it has just been wearing slightly faster than the left tire ?????......Mike....:thumbup:..............PS..you identified both left and right tires as the one with the problem , that's kind of confusing.????????
Right tire wear on the outside
Sorry, I am not good at typing. It is only the right tire (not the left-my mistake) and it is wearing excessive on the outside, but it did not happen all at once. It happened slowly. The left tire looks normal.
When only one tire wears it is usually a result of suspension damage, loose suspension components, or possibly a steering centering (sensor) issue. There are some more remote additional possibilities. Too much toe-in (or toe-out) should wear both tires fairly evenly.
Your Spyder suspension needs to be thoroughly and carefully inspected, and the steering sensor calibration checked.
If the wear took place gradually over time then you've probably had a toe in issue (alignment) from the beginning. Really, the only thing that will give you wear on the outside of the tire is alignment misadjustment.
Toe in will give you wear on the outside of the tire.
Toe Out will give you wear on the inside of the tire.
Worn parts will give you toe out (wear on the inside of the tire)
Bent tie rod will give ou toe out (wear on the inside of the tire)
There is also Caster and Camber, but we don't want to get into that!
Happened to me.
The handlebars weren't correctly centered. BRP now has a tool for the dealers that provides for proper centering.
