Been lurking and thought I'd post on this thread because I'm in the market for tires. Sorry for the length, but I'm kinda free flowing with my thoughts.
First of all, the rear tire. I have an 08 GS with about 13k miles and rear tire is toast. I ordered the Falken over the Kumho or OEM. My logic is as follows: I chose the Falken because the on-line reviews (on automotive boards) gave them higher marks in overall terms, especially in rain and snow. Also, the Falken brand is a higher end brand, being part of the Dunlop tire company and was originally developed as a higher end Japanese tire company.
I didn't go with OEM for several reason. As a long time m/c rider I am not impressed with nor care for Kenda tires. Generally speaking they are at or near the bottom of the food chain. My observations about the rear tire on my Spyder is the same. The wear pattern and life is not acceptable for what it is. Also, when originally mounted (at the factory) it took a ton of weights to get it balanced, which also can indicate poor quality control when manufactured and tends to reenforce my original opinions.
The front: Again, they appear to be rather low quality Kendas, which I'm sure was chosen for their price point by bean counters at BRP. (No knock, just an observation common to all big companies.) The wear patterns are indicative of either bad caster/camber alignment or poor tire quality. Since weird tire wear is a common complaint, there must be something to it. Also, having uni-directional tires it prevents rotation, which would help extend tire life.
The Potenza is a good tire and a viable option, however, if you change the size to a 185 60R14, there is a bunch of other high quality tires available. The overall size is almost identical, being wider and taller by only a fraction of an inch, so I doubt the nanny would have any issues and it appears the fenders clear without interference. However, before making that change: any comments, experiences, etc? I haven't seen anything that specifically addresses this particular question, and yes, I've looked.
I personally think the handling of the Spyder would be improved with improved quality tires.:2thumbs:
