What are Advantages of running Car tires vs Kendas tires ?
What are Advanages of running Car tires vs Kandas tires ?
I've long been a bit critical of running aftermarket tires... mainly because the OEM ones have worked well and are reasonably priced. I usually can get fronts for $60 to $70 each and the rears for $130 to $150.
Seems many wanted to change to save money and get longer tire wear, even though they were getting a good 15 to 20,000 miles off the fronts. To me, buying a different brand to get more miles off the tire just wasn't that important to me....
But now that I've had a bad spate of bad OEM tires...wobble from out of round tires.... it appears the OEM Kenda tires are really pretty crappy... or their quality control is.... who would have thought China could have poor quality control... lol
So I'm putting Bridgestone Potenza's on the fronts this tuesday. Local Discount Tire assures me it's a far superior tire to the Kenda.
One thing I've seen mentioned is that people assume car tires are 4 ply.... not the case. The Potenza's are still a 2 ply tire for example.
I'll post my findings after trying these new tires out.
Well to give a UK perspective ( as if anyone cares!! ).
I've asked the same question of my dealer whose staff are very dedicated.
Aside from the increased ply rating there is another consideration,
namely the weight rating. The OEM Kendas are weight rated at 62 while
a car tire will be rated at 82 to 89 which in real world terms means that
the OEM tire sidewalls flex more easily through curves which for cornering stability is
crucial. What my dealer doesn't know is that in a past lifetime I was a buyer for
a tire wholesaler so with respect to tire specs his explanation rings true.
Of course, as is universally known, we get more wet weather in England than most parts
of the US so wet weather performance is tantamount! In corners with a car tire on a Spyder,
as the sidewalls won't flex as readily, keeping the maximum 'footprint' of the tire on the road surface
is more difficult. Also car tires don't perform at their best when inflated to the ultra-low
pressures which are specified on the Spyder. So if like me you ride your Spyder hard then I
would stick to the recommended rubber...if you don't then you're probably OK.
BUT to each their own and if saving $$ every couple of years is important to some of you
then I guess that's OK too.
Apologies for the ramble but I just wanted to add another opinion.
I put Falken ZE car tire on the back of my RS. Once it wears out I will go back to oem tire. It handles great in dry weather and wears great however I find I slide alot more on wet roads with the car tire. Don't know why. But I'm uneasy with it on wet roads now.
(Original Post edited for brevity)
OEM tire - 2 ply sidewall -2 ply tread
Car tire - 2 ply sidewall - 4 ply tread - The sidewall will be a bit stiffer because of the construction of a car tire vs the Kenda
I agree. I had the Toyo Proxes rear tire and it stuck better in wet and dry than the OEM. I've been disappointed with the Falken's. You might try adjusting the psi. But it may be more the rubber compound than pressure. Typically a longer wearing tire will not give you the best traction.
For example, I had a hard time getting my Falken 912 to hook up at the Spyderfest drags. The last race (which I lost) - I had a .4+ second jump at the light but at 60 feet he had me by .2 seconds. So he beat me by .6 in 60 feet. We ran pretty even after that so it wasn't a HP difference. It could be a simple matter of his skill being much better or it could be the tire. I prefer to blame the tire, of course! :rolleyes:
1. Aside from the increased ply rating there is another consideration,
the
You make some interesting statements here and not being a tire expert I can only offer my perspective. I only pursue this because, as others have mentioned, this is an important subject. I've numbered the comments to make it easier to follow.
I know I'm :bdh: but hey! you can't hurt a dead horse... Right?
1- I don't see the 4 ply tread of a car tire vs 2 ply on the OEM as a negative, especially if the 2 tires are about the same weight (which has been my limited experience). The OEM tire tends to wear in the middle because the 2 ply tread does not offer sufficient resistance to centrifugal force. So at freeway speeds the OEM tire tends to doughnut out giving you less tread in contact with the road, which gives you the classic center wear pattern on the OEM tire.
The car tire with 4 ply tread keeps the tread area flatter giving you better contact with the road surface, a more even wear across the width of the tire and generally, longer tread life. You can add to this that 4 plies will resist puncture better than 2 plies.
2. OEM tire sidewalls flex more easily through curves which for cornering stability is
crucial.
Of course, as is universally known, we get more wet weather in England than most partsof the US so wet weather performance is tantamount!
2. I agree that the OEM sidewalls flex more easily and this (along with the 2 ply tread) will give you a softer ride. But too much flex will allow the tread area to lift reducing tire contact and reducing traction.
3. In corners with a car tire on a Spyder, as the sidewalls won't flex as readily, keeping the maximum 'footprint' of the tire on the road surface
is more difficult.
3. I am really trying NOT to be argumentative here. But If you look at any of the videos of a Spyder in hard cornering you'll see that the OEM tire sidewall flex allows the inside tread area of the tire to lift off the roadway and the outside tread area to roll under. You don't even have to see a video. You can feel the OEM front tires giving up on hard turns because of the weak sidewalls. People are increasing tire pressure in an effort to compensate for the OEM sidewall collapse. Of course by raising tire pressure you start to lose the softer ride advantage created by the weak sidewall and 2 ply tread.
The car tire, having 4 ply tread and a bit stiffer sidewall, will tend to keep a flatter profile and more tread on the road during hard cornering. Granted, the ride may be a bit stiffer but I have not noticed any real difference in that respect.
It only stands to reason that the RT, being heavier and having a higher center of gravity, will suffer what I consider to be the negative effects of a soft sidewall to a greater degree than the lighter, lower RS.
4. Also car tires don't perform at their best when inflated to the ultra-low
4. Now here is were we might be able to agree, at least in theory. Tires are designed to run a certain pressure. But I am assuming (again, not being a tire expert) that this is based on weights at or near the rated loading, which obviously our Spyders do not approach.
Without scientific testing I can only go by personal and other's experience. While I am not particularly thrilled with my current Falken 912's traction (not horrible, by any stretch, just not stellar) I think it has much more to do with the rubber compound than pressure. I've run from 26 psi to 32 psi in the rear tire with the higher number giving me better all around performance. It is the fronts, at 20 psi, that are significantly lower than called for and they seem to do fine. I haven't experimented with the front tire pressures much.
So, while I agree that the potential is there for reduced performance, I am not sure this has been the experience.
5. BUT to each their own and if saving $$ every couple of years is important to some of you
5. I and others who have used car tires do mention price. I can only speak for myself but I don't get car tires because they are cheaper. I get CERTAIN car tires because I THINK they have the potential to be better. I DO NOT think all car tires are superior to the Kenda's.
I would pay more than OEM price if I thought that it was a superior tire. Traction, control and performance are very important to me and I'm not going to willingly compromise these to save a few bucks every few years. The reason I mention price is simply that I see it as an added bonus.
You're a good guy and I very much appreciate your perspective. It's not a battle to be right, it's a group effort to get to the facts. I want to be clear that I am only giving my opinion and I'm not trying to talk anyone into getting a car tire. You can't go wrong putting the OEM tires on your Spyder. But some of us are always looking for something better. Sometimes you come up with gold, sometimes all you get is a pile of dirt.... :ohyea:
I still have my original front-tires on my RT - in the 17.500 mls here in the Alps (lot of rain) I never had the feeling that I would need "better" ones , its not possible that the front looses the Grip in the curves , also on wet roads .. BUT with the rear Kenda I could not ride in the rain without "sliding" through the curves - (my wife hates that - I love it) - so i changed it after 6000 mls (still looking good) to a standard european car-version (Fulda Carat) and now to a Falken912 .. feels much better !!
No knowledge worth a tinkers BUT
:yikes: That I am even posting on this thread indicates a serious problem. :roflblack: First I have 2 dealers within a 5 hr drive and dealer 1 will install any tire I'd bring him....oh wait, if I buy oem's from him install is NO CHARGE. Otherwise there is a minimum shop charge of $300 (3 hrs) to install rear. So my $ brain slowly calculates ......
dealer 2 refuses to install anything but oem's .... By now you are asking what is MB doing posting here...for me it was ALIGNMENT .. I was wearing my fronts out on the inside edges in about 8-10k...4 different dealer techs basically said "can't be corrected..BRP design flaw :banghead::banghead:"......well folks I'm here to tell you either the gremlins fixed the issue OR the alignment shop that I have trusted many vehicles to....cause I am at 15+k on this front set of oem's and they are showing very little wear. So I have no personal dog in this hunt other than uneven front wear? You might consider alignment...ok going back to bed. Headed from ABQ, NM to Moab, Utah in a few hours. So better add a few zzzzzz to the energy PAC!!!!
I agree in terms of the front tires.
Anyone who has followed my posts (my loyal following of -0.002 members) knows that I had a horrible issue with bad alignment when I bought my bike. The first set of tires, the left one was nearly bald after 9 K miles.
New tires and new alignment. 2K later, the left started to show excess wear, not as bad but still more than it should.
New alignment with new BRP techniques/tools.
After an additional 13K the fronts look great. I've got LOTS of miles to go.
The rear ? I keep the pressure a little lower, about 25 psi to minimize the doughnut affect, but I'm not pleased with the mileage. I'm on my third rear tire.
I think I'll keep OEM on the front and consider some other option for the rear.
I would also be greatly interested in how car tires affect the gas mileage. I'm thinking stiffer tires should give some theoretical improvement. I'm curious if it's measurable in real life performance.
As always, my free advice comes with a double your money back guarantee.
Hey Baja Ron... you're attributing the above quotes to me...... when it wasn't me...... just FYI.
Well, I used to think you couldn't go wrong with the OEM tires.... but right now I have 4 out of 4 OEM tires that are causing wobble. All 4 different tires show terrible bounce and wobble when spun up on a balancer... while the rims spin true.
Two of the tires have 8,000 miles on them. The other two have less than 50 miles on them... wobbled from day one of mounting.
I guess I can understand my 8,000 mile old tires developing a wobble... especially with the terrible roads we have up here in Michigan, but the brand news ones... no excuse other than bad manufacturing/quality control.
Been a frustrating, yet easy thing to track down... just needed someone to spin them up and confirm what myself and many out here thought... that my tires were whacked.
Quality control not withstanding you can't go wrong. Sorry to hear you've had this much trouble with them.
And the name of your son's store is: in case I'm in New York when I need tires.
Netzley Tire and Auto small garage, but big by some standards. Appointments only and great service, just get ahold me and I will se you up.
TIRES
Well Randy I apologize for (Not Being an Actual Owner) of a Car tire On a motorcycle. I just relayed some info from the owner of OK Tire who has been in the motorcycle and truck and passenger tire business im guessing most of his life. I dont think anyone here is a tire engineer and if there is please speak up. I also look at it from a DOT department of Transportation side of things. If someone is in an crash on a Spyder and they are running car tires which by law are not approved for Motorcycles the insurance companies will probably eat you up.
And to Kinggeek this was NOT a brp dealer who gave me this info read my post.
INQUIREING MINDS WANT TO KNOW
Now that the statement has been made (above in last sentence) Who among us :spyder2: Ryders / Owners have direct connection to or work for INSURANCE Companies or Underwriters?
Can you or anyone clear the air about ROADSTERS involved in accidents while having Cage tires on VS Moto Bike tires on where the INS Co. Canceled the policy for running Car tires on their :spyder:
I for one would be a little upset if my INS. Co. left me hanging out in the wind just cause (if) I had Car Tires on my :spyder2:. This can also open the door to be blamed for the accident even if it were not my fault.
I simply just want to protect my investment. Wouldn't you?
I just talked to my tire dealer about this last week, I ordered the new 2013 15inch wheels for my 2011 rt limited. I asked him about people running car tires on Spyders and he told me it`s a very bad idea. The car tire bead is not going to be the same as a Kenda tire`s bead and because of this the car tire cant seat properly on the spyder wheel. This dealer has been in the tire business for 42 years and his motorcycle mechanic has been in the business just as long. They do most of the Spyder work here and are very knowledgeable in this stuff. Mounting a car tire on a Spyder wheel can cause a side blow out and that can be very bad. I know a lot of people here run car tires on their bikes this is just info from a very respected dealer...do your home work and be safe.
Might be an objective source of info..........................might not. Just sayin..........................The only real safety determinate for a non OEM tire on a Spyder rim would be the tires bead is seal compatible with the rim. I seriously doubt Kenda is the only brand providing that. Any good tire/wheel store should be able to help the curious ID tires compatible with the stock Soyder rims.
RIM ...BEAD THING
The whole RIM .....BEAD ,,,thing has been discussed and decided here in this thread already...........IT IS NOT AN ISSUE ! ! ! ..............Mike :hun: .....:2excited:
Just saw this thread and have many posts to read before I comment . If I do, I am up for my 3rd set of rear tire as we speak. :read::roflblack:
We'll.. I'm not in the insurance business, but I have totaled a Spyder and dealt with the claim. There was zero interest in what tires I was using. There was no problem that I had tons of aftermarket, self-installed mods either. Shocks, swaybar, electrical, etc.....
The idea that an insurance would (or even could) disqualify covering your Spyder due to running car tires is ludicrous. Reminds me of the old rumor about if you leave your keys in your car and it's stolen your insurance won't cover it (also not true).
:agree: The most likely place the substitution of car tires could come into play would be during a state inspection, as far as I can see. Fortunately Michigan doesn't have those (yet). I suppose if a blowout caused a serious accident, with significant injuries to others, the insurance might inspect the tires, but that would be pretty unlikely for a Spyder accident. Who spreads these rumors?
RUMOR SPREADERS
" RUMOR MONGERS " , :yikes: :lecturef_smilie: :agree: :roflblack: :roflblack: :roflblack: :roflblack:.....?
As for #1, some other members have put something other than directional tread tires on their Spyders and have gotten front end shimmy when closing on or exceeding 95+ MPH.
​Spyderrocks post brought several question to the surface and I wonder who has the answers?
1. Why use a directional tire and rotate it because if you move them side to side they are running the opposite directions. Unless you dismount the and remount them on the different wheel. That is a lot of labor and expense.
2. Why would the tire side bead be a problem? The beads only purpose is the hold the tire on the rim and provide a sealing surface to hold the air pressure in.
3. Why would an automotive tire at the same speed rating, running on a 900# Spyder be more susceptible to side wall blowout then if it were mounted on a 3,000# car chassis driven down the same road?
I am curious and inquisitive?
