What 36mm wrench to remove rear tire?
I have found that if I use a ratchet type tie down strung from the rear tire to a footpeg I can put enough pressure to keep the wheel from moving while torquing the nut.
Maybe your bike is different, but when I'm adjusting the belt, I have someone press their feet hard against the back of the tire to pressure the wheel forward. Works for me.
You're right. I got it bass ackwards! Just remembered how the adjusters work. I was trying to figure out why, if the axle wants to move forward, I put a wedge shaped block between the tire and swingarm on the brake side to keep it from moving.
