If it’s C210A it usually means it can’t set the ride height properly.I've had mine in the shop twice for a suspension code fault. Picked it up today but, on the way home, it showed the same fault and code. I called BRP Customer Support; they were very helpful and set up a case# on my bike, so I have to return to the shop for the third time for the same issue.
We just picked up a new 2022 leftover RT Limited and on the way home the suspension Fault warning came on several times in the 70 mile drive. After putting gas in, the VSS warning came on and turned off. Spyder performed normally for the remaining 33 miles home. I’ve called the dealer we picked it up from and they said they will look into something and call me back. A friend thinks it’s a low voltage from the battery. The link you described above is installed and the shock is installed with the spacers. This is a nice machine, smoother, maybe calmer is a better description that our 2013 RTS SE5. But it looks like it’s back to the dealer for a fix. Is it safe to ride? I didnt note see any code numbers displayed, just suspension fault many times and one VSS after starting it at the gas station.Yes, this is a very common failure when dealers/techs don't do the pre-delivery properly! But Bolt A itself shouldn't connect to the Swingarm at B, it's the other end of the 6" or so long link/arm that looks like it's tucked up out of the way, going forward from bolt A & heading toward the top left of your pic that should be connected to the swingarm at B! Why so many dealers/techs just can't manage to follow the instructions and do this simple thing before handing over a Spyder to a new owner is really beyond me! :banghead:
With any luck, if your Spyder is like most I've seen where connecting this arm before delivery has been over-looked, then I think you'll find that the BUDS calibration thing has been done already at the factory, and all you need to do is jack the bike up a little so that the swing arm extends down juuust enough, then pull the link down and connect it - you'll need a bolt to thread into the connector on the swing arm too. Once that's done, just check to make sure there's some air in the air bag - I've found they generally need about 5-10psi in them in order to let the system set itself going properly, so if the bag is empty, you might need to add a touch of air via the Schraeder valve that should be under the seat (do 2023 models still have that valve?! :dontknow: )
And NO, you really shouldn't be too worried about a burned-out compressor after such a short while without it connected, especially since you got the 'suspension fault' message. Personally, I'd just take a bunch more pics and connect the link myself, taking pics of EVERYTHING you find and do, so that if you DO end up needing to go to the dealer, you have that fully documented. And I'd certainly be giving the dealer a serve about it, but unless they are prepared to fix it as & when you arrive there AND to let you stand there and watch everything they do so that you KNOW they've actually done it, then I wouldn't be leaving it!! :lecturef_smilie:
For most new Spyders delivered like that, it's just a matter of finding a suitable bolt; then pulling the link down/jacking the frame up so the swing arm droops a small amount; connecting the link to the swing arm with the bolt you found, plus making sure there's a little air in the bag to start with; then riding off! It should take maybe 10-15 minutes MAXIMUM, likely somewhat less if you've ever spun a spanner before & can still get down there & back up, cos it's really nothing difficult at all....
So if you want to risk leaving your new Spyder sitting around at the dealer's for who knows how many weeks while it's waiting for a tech who's already shown that they're basically incapable of doing such a simple thing, then that's your call, and I do know there's a principle involved, but for the maybe 15 minutes that it'd likely take you to do it so that you KNOW it's been done, I certainly wouldn't be handing it back to them &/or trusting someone to work on it who has already shown that they likely need help & supervision in order to follow the fairly basic pre-delivery instructions about doing this! :yikes:
Yep, as others have said, that certainly sounds like you've got a crappy battery that's causing these faults to show - it's very unlikely that there's anything else wrong. It should be safe enough to ride, as the errors aren't from 'real faults' as such, but they are from failures in the electrical system and any 'bigger' failure could leave you stranded away from home/far from help, so it'd pay to bear that in mind.We just picked up a new 2022 leftover RT Limited and on the way home the suspension Fault warning came on several times in the 70 mile drive. After putting gas in, the VSS warning came on and turned off. Spyder performed normally for the remaining 33 miles home. I’ve called the dealer we picked it up from and they said they will look into something and call me back. A friend thinks it’s a low voltage from the battery. The link you described above is installed and the shock is installed with the spacers. This is a nice machine, smoother, maybe calmer is a better description that our 2013 RTS SE5. But it looks like it’s back to the dealer for a fix. Is it safe to ride? I did note see any code numbers displayed, just suspension fault many times and one VSS after starting it at the gas station.
  ) maybe see if you can get a new & better battery from the dealer, a battery with at least 350 CCA & 21+ A/hr capacity, like the earlier/better Yuasa batteries that the pre-2020 Spyders came with from the factory. Good Luck!
Truth to the oil changes - when I had my oil change done I had the bolts changed to hex head bolts . He gave me one back and said we only take one bolt off during oil changes and said it only took 4 quarts for an oil change!It seems these days that the techs that are not qualified to do oil changes are the ones that are assigned assembly duty. :gaah:
Time for a new dealer...Truth to the oil changes - when I had my oil change done I had the bolts changed to hex head bolts . He gave me one back and said we only take one bolt off during oil changes and said it only took 4 quarts for an oil change!
