wear on rear tire
This is what i see:
attachment.php
I call them wear guards for lack of a better term. The "A" one is almost flat and the "B" one has about 3mm of depth. I'll look for the red triangle you're talking about... I don't think I've ever seen it.
Tire looks good, lots of wear left.
This is what i see:
attachment.php
That tire has a long way to go. the triangle mark on the side is not red. Just moulded in the shoulder of the tire.
Scrutineer, that block you have marked 'A' is a groove 'breaker' that helps stabilise the tread & make it do what it should with water etc, it is NOT a tread wear indicator! There are generally no markers on the side of the tread or on the sidewall of the tire to show where to find these, but there is generally at least one in each major groove of the tread.
The block you have marked 'B' looks like it IS a tread wear indicator and so there should be a small raised triangle embossed on each side of the tire tread that lines up with that block - the triangle is just a raised triangular outline about 1/4" across and 1/4" tall that is really located just on the side of the tread, not down on the sidewall of the tire. There should be 3 'lines' of those tread wear indicators with a similar block appearing in each of the major tread grooves around the circumference of the tire, & each 'line' should be identified by the triangle markers appearing on each side of the tread to identify that they are the tread wear indicators.
Your tire doesn't look too bad (yet, anyway - it should have a couple more thousand miles in it.) but the CanAm specified Kenda tires are really not much chop for anything apart from keeping the metal of the rim off the road - while for all intents & purposes they are constructed identically to an (exceedingly lightly constructed) passenger car tire that runs on a rim with a 'passenger car' design bead holder & they distort significantly when running at speed, increasing the wear in the middle of the tread well beyond that experienced by anything else; somehow BRP & Kenda have managed to get them classified as a 'Motorcycle only' tyre & claim that the VSS has been tuned to work only with them at the risk of failure.... and yet the manufacturers of these stability & safety systems & all other tires all aver that any tire which matches or exceeds the specified speed, load, wear, and weight ratings for the Spyder & doesn't exceed the rolling diameter by any more than about 3/4" will work perfectly well within the safe operational parameters of the safety systems & vehicle use - btw, it's actually Federally mandated that they do so.... that's what those ratings mean! :shocked:
So if you feel that way inclined, when the time comes around (& it doesn't look like it has yet) you can replace the Kenda tire with an OE spec tire of the same make from a CanAm dealer & put up with the cost & aggravation as well as the poor ride, handling, & tire life; OR if otherwise inclined, you can fit a higher load speed & wear rated passenger car tire that exceeds the operational ratings of the Kenda crap in all respects & provides far better ride, handling & tire life, usually at a significantly lower cost than that charged by the CanAm dealers for the OE rubbish - I got less than 3000 miles out of my original Kenda rear tire before the canvas started to show & yet with little obvious signs of wear have already exceeded 3 TIMES that with the (funnily enough, cheaper....) replacement passenger car tire that is rated higher in all respects than the Kenda & at least for me, works better in ALL respects too!!
Over to you. ;)
Ps: bugga, took too long typing up the epic & it's been overtaken by responses - but it's there now, so for what it's worth... :opps:
Peter, Quit beating around the bush and tell us what you really think!
I agree completely. I put a Kumho on mine and have been riding it for 2000 miles, in the rain and snow, and it is great.
rear tire
Hello folks,
Just crossed 6K miles on my '13 sts, purchased in spring 2014. I've reached the wear mark on the exterior of the tire and maybe I've got 3mm left on the center mark -- so it looks like it'll need to be replaced before the longer summer travel/riding season.
I'm very concerned that this tire made it only 6k miles before needing replacement. Its not like I'm burning rubber and making smoke shows here.... I figure roughly ~500$ to have it replaced -- parts and labor. I realize this is one big bad boy, and the construction is somewhat on the soft side for traction but 6k? Thats two summers of riding and done ?
Can you immagine if regular car tires had that short of a lifespan.
Sigh.
Just had my rear tire replaced at 6400 miles. I purchased bike new one year ago. Cant honestly say that I have done no burnouts! Haha! I probably had 1000 miles left on it put didn't want to change it during the summer riding season if I could help it. Dealer said replacement would probably last longer. Tire $185 and $95 labor.
The 2013 and 2014 model years both had a "high performance" tire with a softer compound. Starting with 2014 models built in June of 2014, BRP went back to the compound they used on the 2012 and prior years. That softer compound wore out fast. I replaced mine at somewhere between 7000 and before I hit 8,000. I have over 13,000 on the Kumho I used as a replacement and have been very happy with it. This link is to the BRPCare comment about the tire compound change.
http://www.spyderlovers.com/forums/...ote-on-tire-compounds&highlight=tire+compound
I was at the dealer last night for a little while talking about just this thing, and of course checking out a new RT. Any recommendations on a new rear tire that is not a Kenda. I will most likely go with either a Toyo tire or a Kumho. My current stock tire has just over 5000 miles on it and I might get 6000 ~ 6500 miles out of the tire so I plan on replacing soon at least before my summer trip. So as I said what is a good tire in your opinion. Thanks
Check around on prices for tire replacement. The dealer in Boerne, TX, told me around $500 for tire and labor. Las Cruces, NM, is going to charge me the price of the tire (around $123) plus $99 labor. Big difference!
We have 17,000 so far on a Michelin. 215/60/15 size on our RT.
I also have a 14 art. I live in Las Vegas so it's very dry here. On my car I've had problems with drying out Michelin tires. Do you think this will be a problem and how's your ride with this tire on the rear?
Hello folks,
Sigh.
You have the old tire compound. Much better after 1-1-15. New tire and installation is $179. If someone wants $500 for a new installed rear tire they are blowing smoke up your -ss.
Rear Tyre
I replaced my rear tyre today, I used a TOYO Proxis T1R cost 99 euros from a local car spares shop, they fotted it but couldn't balance it as the centre hole was too small, took it to local motorcycle shop and they balanced it, now waiting to see how it handles.Toyo Proxis has a similar tread pattern to OEM Kenda.
Incidently, removed shock bolt and jacked up high to allow wheel to dop lower, belt slipped off and on with great ease and kept the original belt alignment. so easy
THAT TOYO
I put a pair of size 185/55 - 15 on my 2014RT 2 yrs. ago ......they stick like GLUE ......actually too sticky, the VSS is constantly triggered................I think you will Loooooooooooooove it also..........Mike :thumbup:
:agree: with all the above. Looks like an almost new tire to me. When it starts looking bald in the center--time to change it out.
