NancysToy
Motorbike Professor
From the calculations I did after seeing the amount of antifreeze after Water Wetter is added, the protection level will go up from the -34 delivered by 50:50 antifreeze to about 0, maybe -10 if you replenish with antifreeze instead of water. Your winters are even more brutal than ours here in Michigan, so I would not do it, but then again our summers aren't normally 100 degrees plus (especially not this summer!) so we shouldn't need extra cooling. Running 3 bars may be comforting to some, but it is just where the Spyder thermostat opens, and not even what they consider normal operating temperature. People don't get upset when their electric car cooling fans run, so why fret over a fan that runs on a Spyder? If you are seeing a continuous six bars consistantly, do something, but if not why worry? JMHOQuestion? Fine in summer but what about winter? With all these so called cooling additives; some say with just water or a little antifreeze added. How is supposed to protect from freezing in the winter. Just woundering in northern Wis. Where it can and has reached -40 plus. I would think more antifreeze is needed. 50/50
-Scotty
