Here are two pics that I collected while researching this for my spyder before taking it in.
The first pic shows the water pump/clutch housing. The red wire is in the water pump weep hole. An oil leak would come from the area where the seal is right across from the water pump weep hole.
The second pic you can see the "gap" between the water pump weep hole and the oil side.
The water pump and oil seal share the same "outlet" space on the motor. This area is VERY difficult to see and almost impossible to see with the plastics on. I have some pics of mine on another computer but to get the pics I had to remove the trunk to see.:sour:
From my understanding it's much more common to have a coolant leak there since it's under pressure. The oil is not under pressure at the oil side of that seal so I'd imagine an oil leak to be fairly minor??
I rode mine for about 300-400 miles with a coolant leak at the weep hole and just kept an eye on the coolant level before each ride. Probably went through 10-12oz. Nothing major.
Good Luck Guys!
Good Luck Guys!
