Anyone have a water problem using JT's air cleaner on a 998 engine........
Why do you ask?? :dontknow:
Similar 'oil filled foam' filters are frequently used in a variety of places to STOP any water getting past the air filter - properly cleaned & serviced, a fine oil filled foam filter can prevent mist & rain, spray, etc from getting sucked thru & into the engine with the charge air; they can even force an engine shut down & avoid internal engine damage if they get soaked & blocked by water & in doing so restrict the air flow necessary for the engine to keep running; and they'll do that in situations where a standard 'paper' filter, once it gets wet, will just let water run straight thru & in doing so, can cause the destruction of the engine - at the extreme end, broken pistons & crank outside the block type destruction!!? :shocked:
So why do ask? :dontknow:
Anyone have a water problem using JT's air cleaner on a 998 engine.... If so, how does the water get in the cylinders. Any information will be appreciated...
Never had a problem. How do you know it is getting into the cylinders through the air cleaner...? :dontknow:
I have not had any problem, but I have read a few posts online about water intrusion during heavy downpours..... I am just concerned, don't want to ruin my engine....
Ramrover, by the way you worded your question, are you just asking a theoretical question, like is it possible? Or did you have an engine that had a JT's air cleaner AND water in the engine? Just curious.
If you had water in the float bowl it was from the fuel. No way for water to get there through carb to bowl.
How do you know you have water in the cylinders?Anyone have a water problem using JT's air cleaner on a 998 engine.... If so, how does the water get in the cylinders. Any information will be appreciated...
Ride more, worry less.I have not had a problem, but I have not ridden in heavy rain or let the bike sit in heavy downpours... I asked the question because I have seen a few posts of spyder owners that claim to have had the problem....
8 bucks brings a fair share of peace of mind.
Spyderfish here, 2013 STS, with JT air cleaner. Love the filter, takes away the need for the external scoops, allows access to the engine, and adds a certain edge to the soundprint. Here is what I see wrt the filter
The top of the air filter is concave, with the retaining stud dead center in the deepest part of the concave bowl. Overhead, the steering column is metal mesh, rain easily passes through. A rare coincidence of a heavy rain coupled with a small gap in the mounting stud, could allow water to pass through the mesh, collect in the top cover bowl and then pass through a gap between the stud bolt and the top cover. The water would not touch the filter element, straight into the throttle body.
Not a high probability, but enough to make me install an inverted pie pan over the cover. The pie pan is a couple inches larger in diameter than the filter, it has a flat top, and there is a rubber seal around the bolt. No water is going to collect or drain.
