BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
WATER SEEPAGE
....Question ....could the filter Cover be flipped to avoid the problem ?????? ...............Thanks Mike :thumbup:Spyderfish here, 2013 STS, with JT air cleaner. Love the filter, takes away the need for the external scoops, allows access to the engine, and adds a certain edge to the soundprint. Here is what I see wrt the filter
The top of the air filter is concave, with the retaining stud dead center in the deepest part of the concave bowl. Overhead, the steering column is metal mesh, rain easily passes through. A rare coincidence of a heavy rain coupled with a small gap in the mounting stud, could allow water to pass through the mesh, collect in the top cover bowl and then pass through a gap between the stud bolt and the top cover. The water would not touch the filter element, straight into the throttle body.
Not a high probability, but enough to make me install an inverted pie pan over the cover. The pie pan is a couple inches larger in diameter than the filter, it has a flat top, and there is a rubber seal around the bolt. No water is going to collect or drain.
8 bucks brings a fair share of peace of mind.
