Was it a flip of a coin - Heads it's Torx/Tails it's Hex?
GRHorst
I have to wonder, when ever a bolt was needed in the design of the Can-Am Spyder, did someone there flip a coin .... heads it's Torx / tails its Hex ?
Well I've read that a TORX head provides a higher Torque load. However in my experience unless the surfaces are perfectly mated the Torx will slip easier than a HEX ..... JMHO .... Mike :thumbup:
I think you're right Mike! Just think about what you're using to tighten the fastener with, there is less chance of stripping a torx because you'll bung the head out of it before the threads! I believe you're able to torque the hex's better for a better, tighter assembly. Just my 2 cents!
If you've done a BIG deck job around the house you'll appreciate the "ease of use" for TORX head screws...
I've used them all, Square drive, slotted screws, AND my least favorites, PHILLIPS (:(:(:
Socket head/Allen head, have their place...
larryd
larryd
I agree. They are great for self tapping screws. My confusion is - that why not use all torx (or Hex) on the Spyder. Why some of each???
I think it's a matter of ''looks''. If heads are visible, then the Torx are more visually appealing. Out of sight then the hex are OK. Hexes are probably cheaper also so bean counters like that.
I have .... NEVER had a Hex bolt slip .... Not so with TORX ..... JMHO .... Mike :thumbup:
If a properly fitted Torx bit is used, it's difficult to strip. Care is needed when selection the proper sized bit: it will fit nearly tight in it's socket. If it doesn't, you've picked the incorrect size. I can use a #25 to work on a #27 screw but I will damage both the screw and probably the bit.
Torq can be a much lower profile/thinner head design, similar to a button head cap screw (BHCS). A BHCS has an Allen head socket and are very easy to strip/rip the hex out.
