ArmyJoe
How long do you usually warm up the engine?
One bar.
Seems to me that one would want the engine to be warmed up before putting a load on it (driving it), if possible. Tolerances in the engine are designed to be in specs when the engine is at operating temperature & all parts have expanded into their intended dimensions. While the engine does run when cold, there may be a risk of abnormal wear & tear if loaded before being warmed up. An example of that is that you should only check your oil level at operating temp, not cold.
The manual says 1 or 2 bars. Seems reasonable to me.
:agree: For me, at least 1 bar, two better, if not she gives me a little cough. If you have to not warm it up to 1 bar at least start out slowly...Manual says to let it warm to 1-2 bars. I usually abide by this. Warmup time is less when it's hot out for sure.
When I do take off without proper warmup - I do find myself needing to feather the clutch more/play with throttle on takeoff until she's warm.
The warmup time isn't just about reaching good operating temp --- it's about getting the oil doing it's job before putting things under load.
10 minutes sounds excessive. I've noticed around 5 to be typical - depending on weather, how long Spyder has sat, etc....
"Anyway, this has gotten kind of a little far away from the original question. To me this members issue is excessive and does not matter if the bike is at 1 or 2 bars before ryding...." He may have just exaggerated a little and thats why some of us are just relating what happens with us...
But if we followed the manual to the letter a lot of us would not be happy with the performance of the ryde. Specifically the tire pressure.
What's wrong with the recommended tire pressures?
13-17 front
26-30 rear
I run 17 and 26 -- works fine.
Yeah, but what kind of oil do you use... :shocked: ... :roflblack: :roflblack:
Dan, you are a Baaaad man! :roflblack:
As a side note, our RSS seems to like to be warmed up more than 14 does. The RSS gets real fussy if I just get on and take off. So I really do think there is merit to the idea of letting the engine come up to temp. It sure won't hurt anything!
13-17 front
26-30 rear
Does your wife know you are treating her Spyder poorly? :dontknow: :roflblack:
Michael, yer gonna blow my cover!!It took a few times of fussiness to figure out that the RSS didn't like leaving the stable without a little warm up first. But no worries now since I have started letting things come up to temp. Both machines are much happier campers now! :spyder:
LOL... whatever man... Look up the threads on your own... :roflblack::thumbup:
