StealthSpyder
Hey guys,
Have a few questions that I have not come across in all my research on this forum about the spyder. My curiosity on this topic is due to my DD cager...Audi S4 (4.2 V8). The audi forums suggest about 15 minus of low-load (in spyder terms, non-lugging) driving, under 3k RPM's, for the massive sump of 9.5 quarts of oil to get up to temp, before spirited driving and high RPM's.
So, I'm wondering if the spyder has any special warm up needs as well:
:ani29:How long should I be letting the spyder warm up/idle in the garage before taking off? The Audi forums say that idling is the harshest for the S4, and to fire it up and go within 30 seconds, and that low load driving is the best thing for warming up the oil.
:ani29:In addition...is there a period of time where I shouldn't rev the spyder over X amount of RPM's until it's up to operating temp? With the Audi, even when the coolant gauge on the dash shows up to temp, the oil usually needs ~10 mins longer to get up to temp...wondering if the spyder is similar
:ani29:If so, what RPM's would you suggest I keep it under, and for how many minutes of riding after I pull out of garage?
So far, I've been firing her up and going within 20 seconds (no warm up time)...but keep in mind it's summer in FL, although not sure if that makes too much difference. I've been keeping it under 6k RPM's for first 5 mins or so. Should I err more towards 10 mins of more relaxed ryding before putting heavier loads and higher RPM's?
:cheers:
-=SS
:cheers:
-=SS
