Vredstein Tires
After 1100+ miles with my new ones on the front, I must agree they give greater control. And a softer ride to boot (at 15psi). Plus it now tracks straight down the road instead of the old slight pull to the right... which I think was caused by a defective Kenda; it wore heavily on the inside half, while the other tire wore evenly all across.
Glad you like them ( Vredestein's ) ……….. If that Kenda wore mostly on the inside , I think the cause was poor alignment.... So I would watch the Vredestein tire that re-placed the Kenda ….. Mike :ohyea:
JeriK...I see that you did not list a BajaRon swaybar, yet you are carving the twisties con brio. Is that right, no aftermarket swaybar?
That is correct..no sway bar. Everything I read about them seems to indicate they are helpful when towing a trailer or riding 2 up.. I ride solo and don't tow so never thought I would benefit from that addition. Am I wrong?? I see a good bit about belt tensioners as well but never thought I needed one.
Concerning a Sway Bar like what Ron sells..... It will help your ride performance under All circumstances ...and no matter what you and / or passengers weigh...… IMHO, I would rather have a good Sway Bar as opposed to heavy duty Shocks and Springs.... They work in a similar fashion but not exactly the same ….. Mike :ohyea:
