Valvoline 20-50 MC convential oil in a 2015 St998
Am i ok to put this in for the summer?
I run against the grain ( somewhat ) I normally use this Formula ….. 4 qts. 5W-40 FULL synthetic and one qt. 20w-50 also FULL synthetic … I do this to lessen the viscosity loos ….. jmho .. …. Mike :ohyea:
I have been using 10W-40 Valvoline Motorcycle oil. I would not use anything heavier and it would have to be motorcycle oil for wet clutch. It is FULL synthetic oil.
Why not just look in the owners manual and use the manufacturer's recommended specifications?:read:
Is there a particular reason that you want to use that specific oil? The specified oil is readily available. Just curious
Always a good, No:cus: recommendation. Unless one has PhDs in petroleum and mechanical engineering it's always wise to follow the instructions of those engineers that designed and manufactured the vehicles.
