2013REDRTS
Has anyone ever used E85 in their Spyder? I don't mean only E85 I was thinking about mixing some with my next fill up. Maybe 2 gal. to the 93 octane. Not sure if it would hurt anything. Just a thought.
Interesting question ..... you have folks on this Forum going Apoplectic if you use 87 oct. with only 10% alcohol ................ Using E 85 would be a big mistake ...unless you were Trapped and couldn't move the Spyder without it ....... The Spyder will not be hurt if you use anything from 87 to 94 octane ....but adding extra alcohol is a whole different matter ....jmho .... Mike :thumbup:Has anyone ever used E85 in their Spyder? I don't mean only E85 I was thinking about mixing some with my next fill up. Maybe 2 gal. to the 93 octane. Not sure if it would hurt anything. Just a thought.
Also. it will eat up the fuel lines
Dave
No no no. I put some e85 in my ford ranger one time because it was $1.85 per gallon. That was a bad mistake. Cost me a lot. Had to replace 2 oxygen sensors and a fuel filter to get it to run again. And the ranger has a flex fuel v 6 engine in it. So no its not worth the trouble or repair expense. E 85 is just about nothing but corn syrup with a little gas mixed in. That little $20.00 fill up cost me $300.00 to fix.Has anyone ever used E85 in their Spyder? I don't mean only E85 I was thinking about mixing some with my next fill up. Maybe 2 gal. to the 93 octane. Not sure if it would hurt anything. Just a thought.
