bullant12
On my previous :spyder2: I bought a part from Burnsmoto.com which I can connect to my battery (I actually got the SAE connector and hooked it to the Battery Tender's ring terminal harness that was hooked on the battery. When not in in the Tender, I would connect both and the USB cable would be "hot). I wanted to hook up the USB harness where the rocker switches console is, but I could not fit a square peg in a round pole literally. When I went back to the burnsmoto.com website again, I saw a new USB plug that would actually fit on the hole where the wired comm system would go. After a considerate amount of time and getting the console removed (not easy
pps
, I got the USB socket installed (had to expand the hole a little more) and it is wired to the battery. I can later wire it to an additional fuse box like Tricled's FZ-1 Fusebox.
