USB connector location on 2021 F3S Special series
fullyallamathic
i recently purchased a 2021 F3S Special series. I'm trying to connect my phone to brp connect. But there is no usb connection to found. So does this model come with a usb connector? or do i have to buy a kit?
The USB connector should be in the frunk. Your dealer probably didn't route the wires into it, like my dealer also did not. Pop out the frunk liner and you should find the USB and audio connection wires there.
on The 2021 F3-S Special Series The usb connecter is run thru a hole in the frunk, i took out the frunk liner or compartment (what ever you want to call it} as you would if you were trying to change the battery. and the usb connecter was tucked in there. There is no top glove box on a 2021 F3-S Special series!
There you go. I ran a USB extension cable from the frunk up to my handlebars so I can attach to my phone when needed.
