2023 F3 Ltd with no dual-USB outlet in trunk - did this change recently? Any info?
BigPoppa
Hello Folks,
I bought a new 2023 F3 Limited Special Series last week and I just realized that I don't have a dual USB outlet in my trunk. I checked an online parts fiche and I also don't see a trunk USB outlet listed for my year and model. Just the round blank that's in there now. Did this change recently? I thought all F3 Limiteds came with dual USB ports in the trunks. If not, I guess I'll have to order an aftermarket solution. I'm also going to call my dealer tomorrow when they're open to double check with them.
Just trying to find out for sure one way or the other before I talk to my dealer.
My 2021 F3Ltd had a dual USB. Use it for charging GoPro batteries.
It right in the center and had a plug cover.
Is there an empty hole where one should be?
Hello Folks,
I bought a new 2023 F3 Limited Special Series last week and I just realized that I don't have a dual USB outlet in my trunk. I checked an online parts fiche and I also don't see a trunk USB outlet listed for my year and model. Just the round blank that's in there now. Did this change recently? I thought all F3 Limited came with dual USB ports in the trunks. If not, I guess I'll have to order an aftermarket solution. I'm also going to call my dealer tomorrow when they're open to double check with them.
BigPoppa,
I have a 2023 F3 LTD Special Series also, I do not have a dual USB port in my trunk. I have only the round blank for one.
Deanna
Thanks folks.
Flamewinger, yes, there’s a hole where the USB sockets would be. Like Deanna777 said, there’s just a blank cap covering the hole.
Deanna777, thanks for the confirmation that I’m not the only one. It lines up with the BRP online parts lookup for the 2023 models. Just a blank cap where the USB ports would go.
Thanks folks.
Then take it to the dealer and get them to fix it. It's probably under the trunk (which is removable).
my 2020 F3L has 2 usb ports in trunk, i have my old phone plugged in back there, i use it for bluetooth music and it also keeps the phone charged up also..
brp prolly deleted it for lower cost.. i see they deleted the drivers backrest on the special series also. hummm
I took off my trunk but there’s no USB outlet stashed anywhere underneath. I’ll likely order a generic outlet from Amazon and install it. I did notice that unlike previous years, my 2023 top case uses the LinQ system rather than the removal of the two bolts I’ve seen in DIY videos.
I suspect a change did occur where the 2023 F3 Limited was tweaked compared to earlier years. My dealer isn’t open yet but I will be calling them today to confirm.
Also, FYI, if you have the passenger armrests installed on a 2023 F3 Limited, you have to remove/loosen them to get them far enough out of the way to tilt the top case high enough for removal.
Thanks folks.
BigPoppa,
Under the blank cap there is a hole.
Deanna
fredgal,
I have a 2023 F3 LTD Special Series, with the comfort seat, and no place to put a drivers backrest.
Deanna
BigPoppa,
On my 2023 F3 LTD Special Series my top case has a handle that you can lift and pull off the knob to use.
Deanna
Thanks folks.
BigPoppa,
In the back of the trunk just above the knob that you use to remove the trunk, there is a USB port( there is a cover over it,and it is labeled USB) and a light. ( that only works when the bike is running).
Deanna
Deanna
Awesome! Thanks for the info Deanna! I found it where you said. I didn’t think to look that high in the case. I’ll test it out tomorrow to make sure it’s powered up.
BigPoppa,
:thumbup: Let me know. When I get a chance I'll post a picture of the one at the bottom in the trunk.
Deanna
Thanks folks.
BigPoppa,
I am attaching pictures of the Cover that is over the hole, and the cap that is over it which is at the bottom of the trunk( on my 2023 F3 LTD Special Series): IMG_0226.jpg IMG_0225.jpg
Here are pictures of the USB/and light which is at the top of the trunck( on my 2023 F3 LTD Special Series): IMG_0227.jpg
The light /and the USB works when the bike is running.
Deanna
