Under seat
What is the air valve/port under the seat on the Right side for and why? :hun::dontknow:
I think you mean the Schrader valve for putting air manually into the rear air suspension system? Check your manual for what it is used for.
Can't find the book on right now, it is the Schrader valve. So what would be the range of the PSI for this system?
For my 2017 RTS it is 45-85 psi depending on combined driver and load weight. Your make/model may differ. There should be a chart in your manual that gives diff pressures vs. driver and load combo weight
AIR BAG
:agree: .... AND be very careful if you use any kind of powerful compressor ( ie yours or gas station ) .... The BAG is very small and not strong at all , it is very easy to damage by over-inflation .......... Mike:thumbup:
The Owners Manual on this subject makes me crazy, they took a photograph of a sticker (older models and base models have a sticker near the schrader valve) and used the photo for the manual. You can hardly read it and if you zoom on it the numbers get too distorted to read.
We were surprised to learn that on 2017 F3 Limited there is no schrader valve, the RT Ltd still has one. So if your compressor on the F3 Ltd goes out you're out of luck other than replacing it.
