Ultimate Floorboard Dimensions (to determnie which ones we have)
jfl330
Bought my wife a 20 F3-T that has Ultimate Floorboards on it. No factory pegs.
Not sure which version they are (u-fit 1,2,3.etc.). I think the brake pedal is a bit too far forward for her. If they are not correct for her height, then I can buy the correct ones and change them? According to Can-Am, I think she should be a u-fit #3.
Thanks in advance for the assist.
Jon, My position 5 Ultimates are around 2’5” from front to rear. Each set of Ultimates is a different length as they fasten in 2 spots. Run your finger on the inside of the frame that the boards are connected to, near the front mount point. You should be be able to feel some holes, around 2” apart. That should tell you which position your F3 is currently set to. Let us know what position the F3 is set to.
I doubt Pierre will let you change old ones for new ones. Your only option may be to sell the old ones privately and buy the new ones.
Regards,
Pete
