wetmountainman
Did you mistakenly use 15 FOOT pounds with your torque wrench, instead of 15 INCH pounds?
The dimple has a safty wire hole drilled in it. thread a strong wire through there with a long loop so you can put constant wieght while you turn the plug. The visegrips only give you a quarter or half turn. This way even if you crossthread it you will be able to get it out ...if not come on over I'll get it out.:roflblack:
oh well that didn`t work:dontknow:
Leon
Righty Tighty Lefty loosey! Either you or your Mechanic should write this on your wall. We have all made
this mistake. (except maybe Mike)
Jack
I have given up on "Torque Wrench's". I have three of them and they are all different. I try to apply just plain old common sense. It has worked well for so many years. People usually tighten too much. Good and firm has always worked for me for my airplanes, boats, motorcycles and cars. Never owned a Locomotive so no opinion there. :shocked:
Jack
Leon
Hell must be frozen over because I agree with you.[emoji38] I only use torque wrenches when I have multiple fasteners that need to be consistently the same torque, like a head for example or something very specific.
The routine maintenance stuff is way more common sense.
Like I tell my kid, you have to be smarter than the tool!
Sent from my Nexus 6 using Tapatalk
That's not going to work because the plug is just spinning in the case drain hole. Once you start to drill the plug will just spin.Here is an idea. Go to Home Depot or Lowes and ask for a set of ezz outs. They come in sets. Usually they will have the proper drill for the specific size of ezz out. Drill proper size hole in bottom of plug. Then inert ezz out into hole and turn. The ezz out turns the opposite direction of threads. Right to loosen and left to tighten. Hope this helps.
This will work but will be a chore....place a box end wrench on the plug and drill in about an inch. Tap (flat tip tap) and thread in a threaded rod a couple inches long. Now place a socket just a bit larger than the plug over the plug with threader rod through the center. Place some flat washers and a nut on the threaded rod and slowly tighten the nut. You will be pulling out the threads but you will get the plug out and repair it from there. When re-tapping the drain put grease on the tap to hold the shavings to keep them out of the engine....or again take her in...:thumbup:
I went to my dealer and he has no idea what to do with it and wants no part of it. I also told him that my spyder went into limp mode and I pulled the codes and P0340 came up and he wanted to know how I could tell what code with out a BUDS hook up.:yikes: so i made an appointment with another dealer for 6/13 so i guess i`ll be two wheeling it for a while. meanwhile i will play with it some more .This will work but will be a chore....place a box end wrench on the plug and drill in about an inch. Tap (flat tip tap) and thread in a threaded rod a couple inches long. Now place a socket just a bit larger than the plug over the plug with threader rod through the center. Place some flat washers and a nut on the threaded rod and slowly tighten the nut. You will be pulling out the threads but you will get the plug out and repair it from there. When re-tapping the drain put grease on the tap to hold the shavings to keep them out of the engine....or again take her in...:thumbup:
I was changing my oil and went to loosen the drain plug on the right side and it just spins:banghead:
I don`t even want think what that's going to cost to fix . so much for saving money :yikes:
Leon
Leon
