beefybudds
So was your dimple plug to blame?ended up replacing the clutch cover
Leon
I also have a plug that just spins. Except mine is the other plug.
Leon
Not sure but when i put something between the head and used a. Inpact wrench to slowly take it out only half came out. From now on i will let the dealer do it.So was your dimple plug to blame?
How much did it cost to fix it?Not sure but when i put something between the head and used a. Inpact wrench to slowly take it out only half came out. From now on i will let the dealer do it.
Leon
Columbia motorsportsWho's your regular dealer ?
Who didn't want any part of the repair ?
Do I understand you correctly ? The drain plug is mounted in the clutch cover, and replacing the clutch cover gave you a new drain plug mount ?
781.00How much did it cost to fix it?
Wow $781. So sorry to hear, thats a lot of money. I am starting to think I can not afford my can am.781.00
Leon
Well thats not something that has to be done unless you strip. Your threads .Wow $781. So sorry to hear, thats a lot of money. I am starting to think I can not afford my can am.
Kenn
781.00
Leon
.This was / is not possible ........So don't strip your's because an in-expensive fix as stated can't be done....... Mike :thumbup:To late now, but for future repairs. Just go to the next size up in plug size. Drill and re-tap to the next size up plug. No need to buy a whole cover when this would do it. Sorry you had this happen, expensive.
Chris
I just paid $1071....I think you got a good deal. My parts alone were over $500 with 5 hours of labor.781.00
Leon
Also my plug snapped. But with the cover in place myself and the dealer thought it was a stripped plug.
It wasn't until the cover came off that you could see the plug was in 2 pieces.
So either the dealer torqued the crap out of it or the plug was faulty.
I'm thinking a faulty plug cause I would think the threads would strip b4 the plug would snap in 2 but who knows.
It was the little one.which plug broke the big one with the rubber washers or the little one?
was it a dimple plug?
mine was the little one
Leon
And yes it was a dimple.
That is the same spot my dimple plug broke.my dimple plug broke in half right at the magnet end inside, I think some of them might be defects have to wait and see if anyone else has the same problem. I went back to the OEM plug.
Leon
I spoke with Richard with dimple plugs and he insists the plug was over torqued which caused the break.
I am also back to using the stock plug.
I was going to ask you who put them in for you as soon as I got home tonight and you already answered my question.when I put mine in had my wrench set at 15 Lbs and it loosened up as soon as it got snug, (or I thought it loosened but it was broken) never reached 15 lbs so it wasn`t over torqued
Leon
