Don't remember what size it was, but the smallest open trailer they had that had a wide enough gate was a double axle flat bed about 7 by 14, and you'd need 3 ramps to get the Spyder loaded. For the enclosed trailers, make sure the door is at least 6 feet wide, and you'd probably still need the ramps.
john
To keep the nose from "bottoming out" here is how to figure out how long a ramp you need.
The spyder has 4" of clearance. ...use this number not the 4 1/2 inches. This will give you "goof room" later.
My 2012 RT measures 17.5 inches from the tip of the nose to a perpendicular line drawn from where each front tire touches the ground.
If you have a different year, make sure you measure this for yourself. Don't trust that there have been no changes. Measure it. Draw a line from under the front of the front right tire to the front of the left tire--where the tire touches the ground. Then measure from the tip of the nose to the line.
Measure with a tape measure the distance from the TOP of the bed of the trailer to the ground with the trailer being level.
Divide the measurement to the ground by 4.
Multiply the result by 17.5 if you have a 2012. Use your number that you got from measuring the distance from the nose to the tire line if you do not have a 2012 RT. If you are unsure, as if you measured it three times and got three different numbers, use the largest number. This will give you "goof room."
So if the trailer is 14" off the ground you need a ramp that is:
14 divided by 4 equals 3.5
3.5 multiplied by 17.5 equals 61.25 ...this is the minimum ramp length in inches.
So get a six long ramp.
Make sure the ramps you use are at least 12" wide. The front tires are wider than you expect, and if you miss the ramp, or drive off the ramp you will not get good results.
My trailer is 14" off the ground.
I use a 5' long by 18" wide ramp for the back tire and
two 6' by 12" wide ramps for the front tires.
I purchased my ramps at discountramps.com
