Tin Can
Installed new plugs and wires while doing oil change and maintance. Took the air box off to get to the front wire and plug. After installing both plugs and wires I started the spyder without putting the air box back on. wanted to make sure I had wires connected. ( I know not a smart thing to do )
Anyway got two codes. P0113 and P2228 or P222B I know what the 0113 is a disconnected sensor, the spyder is in pieces.
So 1st Question is anyone know what the P2228orB code is, ans 2nd if I disconnect the battery will i get rid of the codes. Thanks for any help...
