Mad Matt
RT-S PE#0256 SyderLovers Sponsor
Most folks know that Lehman and Victory have teamed up to produce the Crossbow, but if you have not seen it, it is a Victory Vision with a Lehman rear end. Like all the trikes before it, for some reason, the trike builders don't do anything to the steering geometry and the trikes handle very heavy when you leave the stock motorcycle geometry on the front end. There are aftermarket "power steering" triple trees available for some and Kewlmetal makes several different trees for several bikes. Lehman buys the trees from Kewlmetal for the Victory Kingpin and Vegas and they asked us to design some trees for the Vision. It was a challenging project because of the tight fairing and several other companies already said they couldn't do it. Hmmm, well the design engineer in me does not accept the it can't be done answer very easily so we borrowed this Crossbow to get the trees done and we now have some 8 degree over power steering trees for the Victory Crossbow. It is a very tight fit inside the fairing, but we squoze the design in and these trees worked out perfect and really lighten up the handling of the trike. I have to admit, with the power steering trees, the Crossbow is a pretty sweet machine. A little more pricey than an RT, but pretty much the same level of creature comforts. Not the same saftey features. In fact, the ABS is disabled on these. It was fun riding both of these machines, one right after the other just to compare.
Mad Matt
.jpg)
.jpg)
Mad Matt
