Turn Signal - when does the self cancelling signal cancel?
30 seconds is long enough to make someone pull out in front of you thinking you are about to turn right at an intersection. They should be waiting on you no matter what on a left signal. However, that's part of the learning curve; which is why the OP asked this question to begin with.
I've never had a problem with canceling myself even with my heaviest winter gloves; can't understand what's so difficult about pushing straight in. (2014 RTL)
People need to mind their own businesses, not where I'm going. Therefore, I do Not use turn signals.
Cheers!
So how many times has someone had to stop abruptly to avoid running into your rear since you suddenly (to the driver behind you) apply your brakes to make the turn? Nobody cares where you are going just need to know how to adjust their driving to avoid hitting you. Oh and it's against the law to not signal your intention to turn. Cheers!
To cancel them manually push IN not left or right. My 2012 will cancel in30 secs even on a a shallow turn or lane change but I can't wait that long.
