Turn Signal Toggle stopped working.
zhugzug
It moves but first it was working sometimes, now it won't work at all. I think its with the switch in the handlebar. Is this easy to repair myself? Can it be taken apart? If so anyone have any instructions?
201 RS SE5.
Nothing fixable inside. Need a new left handlebar command center assembly. They are different for different years. So I will guess that you mean that you have a 2011 and not a 201. You can buy a new one from a dealer for $159.99 and maybe a little less from one of the online discounters.
PS Make sure everything else works and no fuses are blown out first.
Adventurer....
Seeing as you are going to junk the bad one, if it is the case :agree:, go ahead and open it up and see if you can find the problem. I have taken many (not spyders) apart and repaired them in the past but things are made to be disposable now. :banghead: If I had one I would look to see what can be done....
