Turn Signal Indicators?
Why should they build parts for a bike that is no longer being produced? :dontknow:
I'm sorry to hear that you can't find a set of strip lights in an auto parts store, and make them work! (Hint hint...)
I'll try to load a video and some pics of what I use.....Not much luck with the video, but the LED is in the upper right corner of the mirror, and it's 1/4" square. If I can get the video to load, I'll add it.
Unfortunately, as with almost all Spyder accessories, for RT models only. Haven't seen anything for 2014 ST yet ... sigh ...
Well i got the fenderz lights with blinker module at spyderfest & can see just enough of them to know:firstplace:image.jpgworks great for me. THANK YOU CINDY:clap::yes: & helps me be seen more too :)
Turn signal
I have a little green thing on my Dash that flashes when I have my turn signal on! Just messing with you
Sure it works; I had to use the fix for hyperflash on mine... :thumbup:
Just be sure to view Lamont's video about it, and do EXACTLY as he says.
i have to say, it doesn't on mine either. i've tried 4 seperate times. with the bike running and without, and it will not go away
I followed this video, (without breaking anything) and am quite happy with the results.
The LED's I got on e-bay for $5.00
mirror turn signal
I'm chiming in.. I know this thread is about RT mirror turn signal.
But TricLED just launched 2 new products for F3T mirrors, and We are currently testing these products if they would work/fit for RT's
If and when they do, we will add them into our RT product line up. Thanks all !! :)
You can find more info from below links. I actually put a post about it too under TricLED.
https://www.tricledusa.com/_p/prd1/4636935701/product/side-mirror-yellow-run-and-turn
https://www.tricledusa.com/_p/prd1/4636934951/product/front-mirror-drl-with-yellow-turn-signal
F3T DRL:Amber front mirror.jpg
Follow up on my first TricLED order.
Turn signal mirror lights look like they will be fine.
I think I will mount mine on the bottom of the mirror housing.
Order was shipped QUICKLY and the instructions are good........well maybe unless you have this "man" syndrome that makes you want to jump from step 2 to step 6 just by looking at the pictures. :lecturef_smilie: :roflblack:
Alas, I didn't pay close enough attention to the top mount trunk light strip or the pictures on the web site were a bit misleading.......but I don't think I will be using it. Just can't bear to stick the strip of bare LEDs on there. Sorry but I think that would look cheap.
I will keep the kit, however, because the adapter and wiring and connectors may make it much easier to connect a light strip that looks a bit classier to the top of the trunk. And I have a friend who LOVES all kinds of LEDs for various stuff so the strip won't go to waste either.
Overall impression: Good.
