The Spyder turn signals are self canceling, but it's like 30 seconds. Twice as long as Goldwing.
Sent from my SM-T350 using Tapatalk
I think this been asked before but I will ask anyway.
Is there anyway to make the dash indicator brighter for the turn signals .
I can hardly see mine .
Blind in Ct just installed 2 led bolt lights above mirror wired into signal wiring. Very bright in daylight. Orange in Color.
I bought the kit from Auto Zone, it comes with 2 4" LED stripes. Pulled the mirrors off, drilled a small 3/16 hole in the top corner behind mirror, snaked the provided 24" connecter wire through and spliced into the turn signal wires. Really easy and simple! To do the job you'll need; 3/16" drill and drill motor, 4 solder less wire connectors, wire splicing tool, isopropyl alcohol to clean mirror housing, and about 1/2 hour.Jimboregon, that looks like the answer. Can you give us more info please?
Maybe I misunderstood what Bagger was driving at in my response to his comment above. I took his comment to mean that the signals should be self-canceling if the turn isn't sharp enough to trigger cancellation at the end of the turn, like when doing lane changes or exits. Yes, all the Spyders cancel the signal at the end of a turn, but they also cancel after about 30 seconds in the absence of turning.Not on my F3, it cancels almost immediately after the turn.
Actually, I might have a solution that will work for me. I have Lamont's F3-L LED mirror running lights/turn signals. If I can turn the running lights component off, it will be easy to see the turn signal lights blinking during the day, plus it will stop the amber running lights reflecting off my panel work at night which bothers me a bit.
Unfortunately there is no room on the F3S to do this mod. I have bought a green pilot light today and will drill out the BRP logo on the dash and wire it into the existing light, pics will follow. 100 degrees tomorrow so it may be a day or two!
Blind in Ct .
Blind in Ct .
I did basically the same except I used an LED strip from SuperBright LEDs mounted on the end of the mirror. It's visible by other drivers who are off to the side of me.I have installed LEDs on the last 4 RTs,
