Turn like Snow Skiing? Newbie thoughts...
tehrlich
Just had my 2015 Black RT limited delivered yesterday. The two extra weeks for delivery was TERRIBLE and AWESOME at the same time. It was fantastic that it gave me the opportunity to really study these forums. Thank you for all that participate! It was terrible for me that I had to wait! I haven't ridden a motorcycle in 30 years!
Having the "Do's and Don'ts" thread implanted on my skull, I started her up and went for it. The first ten miles were very scary.... drift, lean, tracking, etc., etc., and I quickly reviewed all the posts in my brain of swaybars and shocks that I'd needed to buy.
Then, I realized how tight my hands were. I tried it again, but made an effort to relax my hands, and the turns came a lot smoother. It dawned on me that the tightened hands were much like tightened feet while snow-skiing. When you are snow-skiing and you are afraid of the terrain, or the conditions, it is natural to lean back in the boots. This gets you out of balance over the skis, and to compensate, your toes will tend to grab towards the front of the boot. It's a vicious cycle because the more you lean back, the more the skis want to get away from you.
I was a professional ski instructor for many years and have taught thousands to ski. So, I stepped on the Spyder again, and decided to go back to my training days and use that philosophy. I drove over to the "bunny slope" (a local middle school parking lot), and really worked on the turns as suggested in the manual and on videos. I am SO GLAD that I made myself do it. It was invaluable information as I was in a controlled environment where I could change positions, attempt weight shifts, play with the throttle, etc.
My next observations, may be completely inaccurate, so any input is appreciated so that I do not develop bad habits!!
1. Hands on the Spyder are like feet in the ski boots. The outside foot on a turn (the downhill ski) applies more pressure to engage the edges. I found that if I focused on my outside hand to apply pressure on the handlebar to turn, my turns became smoother. The inside hand needed to work, but let's say 80:20. Similar to skiing.
2. Body position, and weight transition, are critical through a turn. With skiing, you have to transfer your body weight over the outside ski, and FORWARD. This will keep the core over the skis and the skis take over. I found with the Spyder turn you lean into the turn and forward. The harder the turn (not just sharp but higher speed, too) the more centrifugal force to throw you out of the turn. Therefore you you don't just lean into the turn, but lean forward towards the inside wheel.
3. Legs and feet mattered. During a turn if I felt my inside leg putting pressure on the seat, it felt like I was "hanging on," and more body roll and skipping occurred. However, when I applied pressure to my outside foot, like a ski boot, it helped me get my weight forward and inside. The turns seemed to just carve, and were dynamic.
I focused completely on hands and feet with body position for 100 miles today and could really tell when I hit the sweet spots of the turns. The more I attempted to attempt a dynamic turn, the more body roll and skipping decreased. I could get it down to where I never felt a lot of sway or jumping. I think I'll get the upgrades eventually, but will try to master the stock setup first.
I have more thoughts on posture, the sweet spot of the Y, and timing of a turn, but would like anyone's input on my observations.
Welcome back..!!
congrats on a fine new ryde..:2thumbs: never snow skied but it sounds like you got it figured out and well on your way to be a pro. Enjoy it :thumbup:
Welcome to the party!
You are "getting it" very quickly. Good for you! :yes:
#1: "Pushing the outboard bar for turns": YES, you'll get much better control and less fatigue this way. It's entirely unlike handling the same curve on two wheels.
Forgot to add…
I used to always tell my students that it was "better to look good, than to ski good!" (As adapted from Billy Crystal on SNL.)
A brand new black 2015 RT Limited definitely does that!!
Keep looking 'maahvelous'! LOL
(I want an F3 just for that reason!)
Anti-sway bar
Welcome---
Just wait untill You get a bajaron bar:rolleyes:.
BTW: I try to put a bit more pressure on my inside ski( outer edge )(maybe 70/30). I get much more controle and it's less tiring as both legs share the pressure.
It's a great analogy--pressing with the outside foot---I"m trying to make it a ingrained habit ( like sking ) so I don't even have to think about ( like sking)
Kaos
that is a perfect analogy as I have been skiing for 50 years it is a great way of putting the body language.
just remember to do your braking if needed before the corner and at the apex of the turn give it a little throttle out of the corner and
try to pick a line and stay smooth with out any major steering corrections through the corner now your carving some turns!!
and much like skiing look through the corner and ahead to set up for the next corner or what lies ahead.
and the nanny helps let you know when you are getting a little squirrely or if you hit some sand or gravel in that turn she helps you out.
have a blast and welcome Spyder lover.:ohyea:
A TIP FOR NOT OVER GRIPPING
This may sound weird and dangerous......but to relax both my hands while riding I actually just release my fingers ( not thumbs ) from the grips and only push to turn. ....Not say push with left, pull with right etc.....This prevents the " DEATH GRIP TENDENCY " of the newer rider.....try it on some gentle roads to see if it helps......Mike :thumbup:
Welcome---
Kaos
Yes, I will probably upgrade, but I want to get the stock setup figured out first.
Skiing... 80/20 was the old-school "centerline" model. The better "shaped skis" give you a lot more latitude for weight distribution and much more efficient.
Thanks!
Great point! Accelerate as you're coming out of the turn. I'll try that!
I kind of discovered this after my forearms were cramped up! Just stretching the fingers got me thinking how tight I was locked on.
:agree: Deanna
I've got about 8K miles on the Spyder and I still have to remind myself sometimes to relax.
Sent from my ASUS ZenPhone 2 using Tapatalk
Great analogy , I was thinking the same thing for awhile now. It's more like a combination of snow skiing and a go cart.
Again, I'm a newbie at this. I've just been trained to dissect every aspect of a turn. So my brain can't help it, but I realize I need input from people that are experienced.
Ive read a lot about 'anticipating the turn .' I discovered that if I focused on my hips and two 'sit bones,' that it was easier to start the turn, carve the turn, and avoid hopping. It also seemed to help me judge the correct radius of the turn. I had been struggling with that in my first 50 miles.
Just before the turn I would lean slightly onto the corresponding 'sit bone.' Then the turn would occur. So right turn, right sit bone, etc.
I also found out that my hips have to be fluid just like in skiing actually. My mindset when I first hopped on the thing was that I just throttled, braked, and turned. But I've discovered that isn't the case at all.
Your body has a region of space (front to back, left and right) that you must use to have the machine carve a turn. Can't just sit on the seat.
