oldgoat
I have had rear brake squeal since the Spyder was new. The final straw was last week when I pulled in to gas up & the attendant came out & asked if the bike was OK as she could hear the noise as I braked to enter the service station.
I know that generation 3 Can-Am rear brake pads are supposed to cure it, but I have lots of wear left in my original ones.
Removed the caliper & then the pads & pins. Cleaned them up & chamfered the pads at the front & rear edges. Put a large fine file over the braking surface of the pads as well just to slightly roughen them.
Bought some thick synthetic grease type product in a small tube that is for quieting disc pads & put a little on the back of the pads where the caliper /caliper piston contacts them & a little on the caliper pins. Put it all back together - got none on the braking surface of the pads or on the rotor.
For the last 2 rides (175 miles each) I have had no rear brake squeal at all & the braking seems as good as it has always been.
Wonder how long the piggy squeal will stay away?
