Trunk Part?????
THE THING THAT HOLDS THE LID UP
My trunk lid will not stay up. What is the part called that holds it up???? Shock, strut..........hard to be repair woman!!!:yikes:
It's a gas strut and someone will chime in with the Auto Parts store part number ........... it's less expensive than OEM & easy to replace ....... Mike :thumbup:
Was it staying up before and now doesn't? If so, then a replacement strut should solve that problem.
Has it never stayed up as long as you've had it? Then, consider adding a strut to the other side so there are two doing the job.
FWIW; 2013RT
Honey, do you have anything mounted on the trunk lid? if not you can just replace the one or possibly adjust the mounting point. If you have added a luggage rack or something to the trunk lid that weighs it down, you might need to add a second gas strut
Here's a link to an earlier discussion Trunk replacement shock on RT trunk
Trunk Gas-Charge Strut
Check with your Local NAPA Auto Parts Store. May need to Google 'NAPA' for your nearest Store. Definitely A Much Better Price Option. :thumbup:
