Tricled RT Mirror Turn Signals
After you've drilled a hole, you fish the wires through the hole to what? Are they fished outside the mirror assembly through the harness hole and are then attached to the wire harness?
I put some LED's on my previous RT but it required taking the mirror totally apart and I won't do that again, but thoroughly enjoyed not having to squint to see the little green indicators.
You remove the mirror on the RT, but no disassembly is required. The instructions are very good.
