robmorg
Just received these DRL's from TricLED. I wanted something that would make me more visible from the front - especially during daylight hours. I think these do the trick, as they are very bright. (The pictures below don't really do the brightness justice - they are brighter than they look here.) I like the high density of this light strip because when they are on, you don't see the individual lights. They look like one continuous light bar.
Mounting them is easy. You clean and prime the A-frame covers (with 3M tape primer to make them stick better). Then you drill a small hole at one end of the A-frame cover to feed the wire through, and then just stick them on. They just get spliced into the wires for the fender running lights with a plug-n-play harness that comes with them. Then you tie up the new wires with plastic wire tires. That's all there is to it.
Here are some pictures, showing a close-up; what they look like in both daylight and at dusk; and finally a night close-up. I think they really do make my RT a lot more visible.
(That's BajaRon's shock adjustor you see in the first picture.)
