Tri Axis Adjustable Handlebars on RSS
ST bars on RSS
I just got done doing the ST install very easy to do and it feels great. Cant wait to go for a spin this weekend if the rain stops.
Can you post some photos. About the cost did you have to take out a second on your house? any more info would be good.jtpollock :yes:
ST bars on RSS
Well heres some installed pics. 165$ for the st riser kind of high but it looks stock and feels great the steering pressure feels smoother now. I still might a 1 inch spacer, got some aluminum on the milling machine ready to go. P9200026.jpgP9200025.jpgP9200027.jpgP9200027.jpgLoading the pics isn't going so well but the bottom two are the new St riser.
RSS bars
Why yes I would. Still need them to make a pattern for a 1 inch spacer that I'm making. What year are you putting them on.
Mxzxgade, I have a one inch brp spacer taken off my RSS I will sell cheap if your interested pm me for shipping and price. Mike
Code:
So let me see if I understand... You used an ST riser to get the correct bolt pattern for the tri-axis bars? Do you have any idea if that would work on an 09 GS?
I don't think he actually installed the tri-axis bars on his RS-S. I think he installed ST-S bars on his RS-S. Me I'm doing the oposite and installing RS-S bars on my ST-S.
And probably what is the most confusing is this thread was originally about the tri-axis bars.
Carl
RT riser on RSS
Well just got my RT riser from ebay and did a quick install on my RSS. No problems really. Had to cut the ziptys to get some more electric wire up the riser, theres plenty to move. Only real thing is mine is a manual clutch and I had to move the clutch lever around a bit so as not to pinch the hose coming off the slave cylinder. Only thing a have to mess with is the cover over the ignition switch, but I think I can make it work.
