Are the Front shocks adjustable?
At best, OEM shocks only had a spring pre-load adjustment; damping rates were not adjustable. The spring pre-load, the two rings in the threaded area on the shock, is hard to access with the shocks installed on the Spyder.
That stated, front end alignment is highly dependent on the laden ride height with passengers and load in the front trunk (a.k.a. frunk), due to the bump-steer in the front suspension. Assuming the front end was in perfect alignment, with slight toe-in, while unladen, then as weight is added and the laden ride height gets lower, the front wheels toe-out. Toe-out adds to the twitchy, touchy feeling when going down the road. The spring pre-load adjustment can be used to bring the laden ride height back up to the "normal" level; but normal is a nebulous term, as I don't recall a dimension in the Service Manual.
If you have Fox Shocks they will have spring preload adjustment. That alone is a fairly big deal. It's criminal that BRP does not provide this on all their machines. The 1st 5 years of production, they did.
Well Ron it's a good deal for the aftermarket shock makers, money in the bank!!
I think you're on the right track. I beleive that BRP saw all the revenue that the aftermarket was getting for shocks and they wanted to cash in on it. They were offering shock upgrades for a while. I'm not sure what happened with that. But they were offering mediocure shocks for about the same price as much better aftermarket products. I think people caught on and it just didn't work out for BRP.
