Tri-Axes Handelbars
remark2013
Just installed a set on our bike and it wasn't that hard of an install. I do have a question I would like answered please. For those that have them is the adjustment for the Up/Down really, really hard to turn? I had to use a ratchet(3/8) and really crank on it to do any adjustments? :dontknow:Just wondering?
Kent.
They are that way so that they do not move after you adjust them
I can turn mine [ with a lot of effort ] with the tool that came with bars
Finles, you Video's are the reason I took on this job in the first place! Having a visual made this job a breeze! All I can say is "You Sir are the Man"!:clap::clap:
Kent.
There is a double set of jam nuts that you loosen, make the adjustment and then retighten to lock the bars in place. There under the rubber cover held in place with turc screws. Remove the screws and pull the robber boot downwards.
