Trailer wiring 2014 ST - how to access it?
motorrijden
Question trying to find out easy way / access to find connector under seat on a 2014 ST limited.
Not sure if I need to remove side bag holders and panels or if there is easier way
The rear bottom tail pan needs to come off. I think one of the side panels too. It's been a few years. So then the saddle bag mounting frames half to come off. That's easy enough. Give the 3 mounting bolts a half turn with the Givi tool, that came with your Spyder new, and they come right off. Then the front bottom mount brackets have to come off. One nut each. Then remove the other screws and the pan comes off. If you can find the connector from there. Good, but I still think one of the sides has to come off.
