Trailer loading problems
Questions
Hello, my wife bought a 2012 RS in April. However I own 2 different types of trailers from the same trailer company and I cannot load it in either due to the low ride height. Is anyone else having to add extra ramp length to load their Spyder? What trailers would you suggest?
I have a Haulmark low profile motorcycle trailer (enclosed) with the ramp door and have no problem loading my RT.
The nose is really low on the RT and many people have had the same problem as you. If you try searching you should probably find some old posts about how others overcame the problem. You may have to wade through a few pages of irrelevant info but I know that this has been talked about in the past. Good luck, I hope you figure out an easy solution. And welcome to spyderlovers.com
A couple of 2x6's about 24 inches long temporarily attached to the end of the loading ramp will probably give you the needed clearance. My loading ramp is expanded metal so I simply use a pin through each 2x6 and a hole in the expanded metal to attach them. If I was smart enough to post a picture, I would. Bottom line is, I bet you don't need to spend the money to buy a new trailer. Cotton
I do this as well - 2 x 6's are 3 ft. long and I even got some ends for them which makes the transition smooth. The bold through about 10" from one end ensures they stay in place. Caution, don't haul your bike backwards unless you remove the windshield.
Lots of solutions...
Extended wooden or metal ramps
Back up to a hill
Prop up the ramps with a 2x6 or 2x8 (or a curb)
Jack up the tongue jack to raise the front of the trailer (still attached to the tow vehicle)
Lower the rear suspension setting to raise the front before loading
Increase the front spring preload setting (or install Elka shocks)
Although it will lower the front of the Spyder a bit more, I would also suggest installing a SpyderPops BumpSkid to protect the bodywork.
There you go...!!
Several solutions... seems the best, as to not have more loose boards to forget or disappear, is the "Tiltahitch" don't have to change or add another trailer to your barn..good luck..!! :gaah:
If you are not in an area of high traffic, try backing your trailer wheels into an indentation of a driveway. The drain/gutter area to the street is lower than the road surface, so the ramp is not at such a high angle. Works for me...
i did about the same thing with a couple of 40" long 2x8's and cut 22 1/2 degree angles in opposite directions on the top and bottom on both ends. works slick!!!:thumbup:
gosh,I thought Harley riders were the only ones that needed a trailer.lol I have been riding with Harley riders for about the last 8 years.When I need a tow I just call AAA and ask for a rollback and that has happened a few times.You just never know when or where.
I put the trailer wheels in a dip too. I also have 2 2 x 6's nailed together with a slant cut on one end, a mini ramp of sorts. I back the tow vehicle wheels up on those to give the trailer a flatter ramp angle. It helps too.
New Trailer Works Great
I decided on an Aluma Trailer. It is very light weight, I can move it by hand even when bike is on it. To drive on and off with out problems the dealer added the two fold out panels shown on the bottom. It works great and looks good.my ramp.JPG
