Trailer hitch
Cindi
How difficult is it to install the trailer hitch? I am fairly mechanical. Does installation require more expertise than simply removing and reinstalling bolts and hooking up the wiring?
Hitch
I just installed a hitch on my 2012 RTS was easy to put the hitch on. The wiring can be a little harder depending on which :ani29: you have.
attachment.php
If you have the BRP hitch, it's a very easy install. The actual hitch takes about 20 minutes. The wiring module is plug -n-play once you take the tupperware off. The directions are spot on.
This is on an RT.
