i bought a set a while ago,similar to fobo i think, and decided to shelve it for various reasons
i am now looking to fit a manually operated vi-air pump for my rear bag,as bike only has schrader valve access and its a pita to check(so i dont)
but i needed a dash mount air pressure gauge...i wasnt happy with things i found on line, so started looking at the TPMS again
fitted to the rear bag only,it was the answer.................so flushed with success,i fitted the other 3 sensors to the tyres
the problem i have is its beyond me to programme.....i cant set the base press(used for the alarm)and i cant change the units to psi,its stuck in BAR...i think thats why i shelved it previously....im ok with BAR,but would prefer Psi....does someone have a 3yr old he/she could lend me for a few minutes to set this thing up?
after powering the display up,i climbed on the bike,only to have the alarm going off at my every movement
so what i now do is press the display into the socket,read the data(albeit in BAR)then pull the display back out a little,effectively switching the unit off(mine dosent switch off auto either)then go ride....i dont need to monitor pressures as i go along,just at the start of the ride is ok for me
i think its a great idea,but only because i can incorporate the air bag
the supplier i bought from($AUD62) is no longer listed but this is the unit:
https://www.ebay.com.au/itm/Externa...583131?hash=item1a7ac075db:g:9g8AAOSwCKRcwZBw
now i just need to fit the air pump and i can monitor my bag pressure:clap::clap:
russ
