Colorrite is a bust on the 2014 Cognac color. and appears to be the same for the OP's color. From a BRP Service Bulletin , #2014-3, Revision 1 dated Nov 15, 2013, Cognac is BRP color B-367, PPG #937659. The store search on the Colorrite web side reveals nothing either.
ColorRite owns all the manufacturer paint codes including H-D and Can Am
https://www.colorrite.com/
Have you looked at VHT website or at any Automotive stores. for the Champagne color?Good job.
https://colorndrive.com/en/touch-up-paint/bombardier-all-ivoire-metivory-met-b390,154522/details
Yep, it's the right color, different name though. This corresponds to the name used in the parts catalog as "Ivory" - "Ivory Metallic". So for some reason the marketing dweebs at Can Am decided to refer to this color as "Champagne Metallic" which is not what Brp calls it otherwise...:banghead:
Deanna
Not really. There is always a chance that something there would come to a close match ( in an automotive store) but I would have to bring in a sample painted piece with me to do side-by-side comparison. The only way I would buy paint online is by Mfr paint code or a cross reference to it. On this, I did search, but no match on "Champagne Metallic" - which is when I then went to the oem parts catalog and discovered that, no such color exists (oem parts-wise). It's Ivory Metallic there - which matches what a third-party supplier calls it, and it even goes by the quoted brp paint code of B390
If you're doing touch ups, and the shade is off a bit, you'll be hating yourself if you use it. That spot you touched up was driving you nuts before, and it'll drive you even more batty if you botched the repair with an off shade...at least, it would me...
It *is* interesting that you got a match with VHT paint. That's Very High Temperature paint, usually for engines, but if it matches and looks good, why not?
Well I order some from here, and will let you know. https://scratcheshappen.com/shop/uncategorized/bombardier-ivory-b-390-touch-up-paint/
