BajaRon
Well-known member
Often yes, but it seems he is leaving the tape in place between the nut and frame. Forgot how I accessed mine, but I reinstalled the bolts with heads forward as oem was. Certainly made installing the nuts easier and was able to tighten the nut vs spinning the bolt. Do know the Spyder had weight on wheels when tightened.
Yes, the tape stays. But it is very soft. It will crush and you can still turn the nut easily. It's just a temporary aid that really makes no difference after it does the initial job.
Of course, any way that works for you is great. I tried this install many different ways and found this to be the best for me. That's the only reason I recommend it.
