To Steve (BRPcare) about DESS issues
personally i would sign a paper allowing you to disable the dess system so i could ride with the confidence of not getting stuck anywhere. i feel BRP should really think about that
I would also be interested in this. At least until a reliable solution is found.
You own the machine, not Can Am, find someone that has the BUDS setup, outside of a Can Am dealer and have them switch it off for you. Do not say a word and if it is stolen, no one needs to know.
I'm all for turning it off. Do you know of anyone that is willing to do this?
I'm chiming in; it would be very helpful to be able to turn this feature off.
Many of us take long rides, and could be the difference between an hour or two stop at a dealer to flash the software (with the option to turn it off as a preference), and loosing a vacation.
SOFTWARE FLASH
From everything I've read here and personal experience " FLASHING the SOFTWARE " will not solve the current issue with the DESS failures most are experiencing NOW........The MODULE must be re-placed........For everybody ( but me ) it's about 2 hrs...because the FRUNK has to be re-moved and put back on......the MODULE is two bolts and two plugs ......I'd LOVE to know if the MODULE can safely be moved to somewhere more accessible ( for the dealer or DIY'er ) ....like possibly the REAR TRUNK AREA which is further away from the IGNITION SWITCH and KEY........................HOW ABOUT IT STEVE ??????......This might even prevent the problem.....................just trying to help with this conundrum :banghead::banghead::banghead:............Mike :thumbup:
Longer wires, cell phones in the trunk, may not make that location a good spot.
Nest time the frunk is removed, I will see if I can make it a QC type mount / location.
Do you know anyone that has actually done this and it works as we think it does? Really as simple as just turning it off?
Yes and no...No I do not no anyone, if you have the proper version of equipment and software rev, plus a proper key, it is supposedly as simple as you mention. Just got off the phone with another member here about it, and they clarified some stuff they learned as we have shared some knowledge.
I'm thinking the 916 DESS module will be a good one. No real reason other than my old race number.
Ok, I have done a little research. To deactivate the DESS you/someone will need a MegaTech Key for their BUDS system. When you deactivate it, it erases the key codes where ever they are stored. If you want to re-activate the DESS, the keys will need to be reprogrammed into the bike. With software version 3.7.2 this can be done with your keys, no master key needed. (This is what is suppose to happen but hasn't been tested)
I'm still trying to find out about a pin# to over ride a DESS failure.
More research, there is no pin# option at this time. I do have the Megatech license and I can disable the DESS.
I see that Steve finally responded, In light of the fact that it started happening on the 14s, and again with the 15s, not sure about the 16s, IMO its not very high on BRP's fix it list. IMO the right 10 year old kid could solve this issue in days. We are not talking about a million lines of code.
Of course, they are short sited on the value of customer satisfaction vs R&D to fix this and other issues. The MBAs only job is to cut cost and to determine the cost of fixing vs the cost of lawsuits.
Hi everyone,
We've been following this thread closely and I wanted to make sure I got the right information before posting here.
Steve, has BRP been able to determine anything definitive about what kinds of external radio interference may cause the key code to be read incorrectly? If so, has the newest module been made more resistant to, or more tolerant of, such external signals?
Without delving into too much detail, I know that the main change in the new version of the module is to allow more time for the system to ensure that the proper key is detected, regardless of external signals.
it appears that the new 710004916 DESS module is not correcting the issue.
If you're having a DESS error come up with the new module, it's possible that the error in your case is not due to the module itself, but elsewhere (ECM, Antenna, Key, etc). Your dealer is properly equipped to check that out for you if you do get that error message.
Every time I get in the car or pickup to drive to coffee or church 30 miles away I run the risk of some idiot crossing the center line and crashing into me! Do I let that stop me? No! This is to say no trip, regardless of what vehicle you use, is guaranteed to not end up with you stranded somewhere. If we let the possibility of a failure keep us home, we'll never enjoy getting out.
Just sayin'. Some of you guys, like Sam Mac, just simply worry too much. If you let the fear of failure hold you back you'll miss out on 99% of life's pleasures.
Hell, your wife could die of a heart attack the next time you go fishing! Are you going to let the fear of coming home to find her dead stop you? I doubt it.
Get real, guys!
While I agree with you completely.... the concerns here are a little different. There is the worry of operating a untrustworthy vehicle. It would be like going on a vacation with very bald tires...or going on a cross country trip with a 27 year old car with mechanical issues.... you never know when the vehicle will strand you. I think that is the concern....unreliability.
I have a 2014 ST-L and have had no DESS issue. I hope I don't and will ride in the mean time with confidence in my :ani29: . But.....if the DESS pops up....I would be very reluctant to go on a distance ride and get screwed. Could you imagine being hundreds or a thousand miles from home, stranded...huge tow bill and associated costs to get back home ?
Still thinking positive here :thumbup: Felling sorry for those with issues :bowdown:
I wondered about that. 2013 and earlier models kept trying for a full minute before giving up looking for the key to respond correctly. Yet 2014 and later seemed to give up only after a couple seconds.
Steve
I get it that BRP is in business to make money. I'm not about to tell you guys how to run your business but as a former business owner the best way to lose customers is to not deliver what you have promised and to cause them problems. I understand that the DESS system is designed to defer theft. Just my 2 cents, having my Spyder stolen is not at the top of my concerns. I am more concerned that it won't start while I am far away from home. I get it that you guys are probably trying to come up with a solution to this problem. It would seem to me that in the interim period until a solution is found that it may be prudent to allow your dealers to disable the DESS system if an owner requests that it be done. I for one would be willing to sign a release of liability for the disabling of the DESS system. That said I am looking at side by side off road vehicles for use on my property and Can Am will not be considered. $$$$$$ that Can Am will not get from me.
Thank You
Sam Mac
What version and what key?
Again, to Steve BRPCare
Hi everyone,
Here are the facts:
  • The system works as follows: When the vehicle is started, the DESS module looks for a signal from the key, relayed to it via the antenna (which is just an extension of the module itself). Then, the DESS module lets the ECM know that the proper, authenticated key is present and matches the ECM, and the vehicle can be operated.
  • There are different possible causes for a DESS error, and different ways for the error to manifest itself. For the vast majority of cases we've seen, neither the ignition, antenna or ECM needed to be replaced. For folks who did experience a DESS issue, replacing the DESS module itself to the latest part number is the appropriate fix.
  • If, somehow, you've had a DESS failure after having the DESS module replaced to the newest part number (that occurred more than once, was not due to interference, etc), it could point to an error in one of the other aforementioned systems. Your dealer can diagnose it for you, look up any error codes and if needed our techs will assist them.
  • For obvious reasons, BRP doesn't recommend nor support disabling of the DESS system.
Incorrect. If I don't respond right away, it's to make sure I have all the facts straight so that I don't provide any misinformation.
I originally started this thread with a fairly simple question addressed to you. 99% of what is posted here has nothing to do with what I wanted to know about clearing the error. I apologize for the other stuff that has accumulated. My question has to do with the comment about cycling the ignition 4 or 5 times when the error is active on the screen. Does this clear the system and allow it to reinitialize ?
Thanks for your time.
Hi everyone,
Here are the facts:
BRPCare: Thanks for the info. Deanna
