To kill or not to kill (switch), that is the question
RGVSpyderGirl
Shutting off Spyder -- neutral or kill switch?
For my RT with a SE5 transmission, the manual says to put it in neutral, set parking brake, and turn key off. The girl who sold me my bike and went through all the shut down steps said she always just hits the kill switch then sets the parking brake and turns key off. That's the easiest but does it hurt the engine to continually turn it off with the kill switch. :dontknow:
I always use the kill switch. Just in case there is ever a problem while riding, and you need to hit the kill switch, it will be ingrained into you brain. I have an SM5.
:agree: The kill switch wouldn't be there if it wasn't to be used.
It's a very good habit to get into to turn the engine off using the kill switch. Just remember to turn it to the "run" position when you go to start up the Spyder again!!!
A bike mechanic friend tells me that from his perspective, all the kill switch adds is a other point of failure for the bike to leave you stranded somewhere. He sees nothing it adds that the key doesn't already handle. He says he's had to replace a number of them over the years.
I agree with my friend and only use my kill switch when I hit it by accident.
Always use kill switch. Anyone who rides much will tell you this-- been a well known preference for many years for most bikers.
It's a safety reflex issue. If that is how you're programmed to shut the bike off--- that is what you'll do during and emergency should the need to shut her down arise. Never had one fail.
The manual also recommends you practice doing and emergency shutdown while riding so you know what to expect.
I always do the kill. Personally, I recommend shifting into neutral before the kill, just in case you decide you want to move it around a little w/o bothering to start it up (easier to push in N). I often shift into N while approaching my destination, hit kill, coast up and hit the brakes.
I always use the key to turn off the engine, I did it with my wing and I now do it with my :spyder: I don't touch the kill switch
Be Safe
AC:spyder2:
I agree with you and your friend. Living in a small farming and ranching community and having a motorcycle background, I wound up working on lots of friend's four-wheelers when they started becoming popular with farmers and ranchers. Most of the time the fix was as simple as putting gas in the tank, turning the gas petcock on, or cleaning an air filter. I replaced a few fouled plugs, a few batteries, and occasionally repaired some wiring that was destroyed by running through a mesquite or cedar bush. I also turned on a few kill switches that had been turned off and not turned back on but the only real part failure I ever found was two defective kill switches. I really think I can reach the key about as fast as the kill switch.
Cotton
I have ridden Harleys and now Spyders. Kill Switch should always be used as indicated by many.... safety first!!
Gee... I had been just stuffing the tranny into neutral, setting the parking brake and turning the key off... Your logic behind using the kill switch is solid and I believe that I'm going to try and get used to adding it to the process. Thanks! :thumbup:
A close by Spyder Rider called me the other day saying his RS SE5 would not start and would I come over and check it out for him.
I got on his Spyder switched on and realized Spyder was not in neutral so had to push brake to start....Safety lock out on SE5...
Freebob...:doorag:
Huligan kill switch = trigger. Personally, I use it every chance I get.
Sent from my Xoom using Tapatalk
Stop, first gear (never in reverse even if headed down hill), parking break, ignition switch, kill switch. (Done mostly for theft purposes)
