OK, I just put Kumhos on the rear and I need some good news after all of the comments I have seen. What pressure do you recommend? I am currently running 20 lbs.
Leon
Unless you are REALLY HEAVY &/or you're always riding at or even beyond the Spyder's carrying capacity; or maybe riding in 100°F+ heat at Freeway Speeds all day; then I really doubt you'd ever need an a/mkt rear tire fitted to a Spyder to require as much as 20psi! :shocked:
For most people running any a/mkt tire that meets or exceeds the OEM Kenda's Speed and Load specs on the rear of their Spyder, I'd expect 18psi is likely to be the top of the pressure range required, and with a std size Kumho Ecsta on the rear of your Spyder, I'd think that 18psi would work pretty well for most to start with. But as soon as you start to notice any centre tread wear developing or it starts losing traction in the wet & cold; and almost certainly by the time you reach about 10,000 miles on that rear tire, you should gradually start dropping your pressure in order to maintain the traction and keep the wear even across the tread face. Personally, I'd think you should've dropped 2 psi by or around the 10,000 mile mark, or whenever the tire starts losing traction in the wet & cold; and then I'd expect you to need to gradually drop another 1 or maybe 2 psi sometime after reaching about 15-20,000 miles, or when those same conditions mentioned above start becoming obvious again!
But I wouldn't ever drop your a/mkt rear tire below 14psi!! :lecturef_smilie:
IIRC, the last Kumho I ran on the rear of my RT still had good tread, traction, wet weather capabilities, and was still at 15 psi when I swapped it out at about the 40,000 mile mark, which I did only because I was just heading off on a fully loaded 10,000 mile tour with expectations of doing a lot of hot high speed miles and a fair bit of riding in monsoonal rain on less than the greatest road surfaces... So I changed brands & replaced all the tires before starting that trip; and I'm actually still running those tires now, with well over 10,000 miles on them now!
Over to you, and if you start to notice that your rear Kumho running at 18psi has started losing traction in the wet, then it's probably cos the tread compound has hardened up a little thru use/exposure to the elements and the tire's now over-inflated by maybe as much as 2psi! :lecturef_smilie:
Enjoy! :cheers:
