Tire valve stems
Yeah, but you still have to get down there and back up, Paul;).....maybe if they made an inflatable knee pad that you could insert the air hose into after you had finished your tyre work, that lifts the knees to an upright position. :clap:
If you want to check the rear tire easier Harley makes an extension that allows you get the gauge and air chuck up where you can see/use them. It is $10.00 at your local Harley Davidson dealer.
http://www.harley-davidson.com/store/valve-stem-extension
90* stems
http://www.ebay.com/itm/like/281916666018?lpid=82&chn=ps&ul_noapp=true
another idea
http://www.awdirect.com/wheel-maste...2438!&ef_id=VzUaxgAABK852yKZ:20161209002039:s
I'll tell you what if you bring me to Oz I'll check your air for you:roflblack::roflblack::roflblack: and at 70 it aint all that easy for me either but for you Pete I'd do it.
It's really, really easy to check the air with FOBO on the stock stem. Then if you see a change that alarms you, you can check it manually.........and they work fine on the rubber stems according to both the local Spyder dealer and the tyre guy.
Since it takes me ten minutes to get down and back up these days, I wouldn't ride without them.
I am planning to add the FOBO soon. However still need more user friendly way to add Air in case.
90* stems
another idea
I ordered the HD extension valve. Thanks Paul
